1990 Chevy Beretta driver side brake light whont work.
DR.GREASE
Electrical problem
1990 Chevy Beretta 6 cyl Front Wheel Drive Automatic
So heres the problem, driver side brake light will not come on when you press down on the pedal but the other one will. Replaced all the bulbs, fuses are good. Connectors are good. Whats funny is on my turn signal switch, if you pull back on it and push down on the brakes, you wont get high beams, both brake lights will work!. Could be that I need a new turn signal switch?.....
May 17, 2008 at 4:30 AM
BLACKOP555
  • 10,386 POSTS
try spraying the switch on the inside with wd40 and working it around, if that doesn work the switch is bad.
get one from the junk yard.
May 17, 2008 at 7:53 AM
