1989 Chevy Beretta seatbelts
133,889 MILES • 6 CYL • 2WD • AUTOMATIC
FOXYTIGER
  • 25 POSTS
how do i replace my seatbelts i have a problem snapping it in because the covers have come off where you slide the buckel in and the driver side the shoulder strap has come off and i have to slide it back on or hook it on after snapping the main one in i put a ajuster snap thing on it it helps to keep it together but doesnt seem that safe where do i get new belts and is there some where i can get a manual that show how to do it or is it simple i hope i have a haynes but it shows nothing about replaceing the seatbelts thanks for any help
Jan 13, 2008 at 10:12 AM
  • 31,937 POSTS
Hi there,
it sound like the heater tap has failed, check the temp at both heater hoses when engine is at normal temp, if both not hot with indicator on full heat, either blocked core, failed tap or malfunction of controller.
Mark (mhpautos)
Dec 22, 2007 at 2:25 PM
