1988 Chevy Beretta new battery and alternator,alternator not
120,000 MILES • 4 CYL • FWD • AUTOMATIC
BODHIZAFFA40
new battery and alternator and battery keep going dead,is there a altenator relay or fusable link,if so where are they located,can't even find the fuse box on this car?
Dec 3, 2007 at 11:53 AM
  • 75,988 POSTS
Either you have an electrical short that's draining the battery or the computer is not controlling the field generation circuit.
Dec 3, 2007 at 11:58 AM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Mon Dec 03, 2007 9:13 pm
Subject: 88 chevy baretta
thanks,how would i check for short?could it be a wire from altenator to the battery?
Disconnect the positive battery cable put a test light between the disconnect cable and battery positive post-if the test light lits-you have a short start removing fuses one by one the one that turns off the test light is the trouble circuit.
Dec 3, 2007 at 1:17 PM
  • 75,988 POSTS
See below
https://images.2carpros.com/forum/automotive_pictures/12900_fuse_panel_1.jpg
www.eautorepair.net
Dec 3, 2007 at 1:31 PM
