1987 Chevy Beretta Ingnition Cylinder
LONNIEG
Interior problem
1987 Chevy Beretta 6 cyl Two Wheel Drive Automatic
How do I pull the Ingnition cylinder out
Oct 13, 2008 at 11:00 AM
  • 110,248 POSTS
Hi:
If the switch needs replaced, you need to remove the steering wheel. I don't believe your car has a Driver's side airbag. However if it does, have the repair done by a trained professional.
If you plan to do it yourself and have trouble, let me know and I'll try to walk you through the process.
Oct 29, 2008 at 6:30 AM
