1967 Chevy Bel Air head lamp wiring
SPEVANKO
1967 Chevy Bel Air
I am re-wiring my headlamps. I am using GE 4000 sealed beam lamps. Which wire (low-positive, high-positive, or ground) goes to which prong on the back of the lamp?
Feb 3, 2010 at 11:44 AM
HMAC300
  • 48,601 POSTS
if you have the stock wiring here are the color codes. this is for the stock setup. LH side of plug is black- ground center is tan wire and RH side is Light Green wire. Light green wire is your high beam as thatwire also goes to your center lights...
Feb 9, 2010 at 7:27 AM
