1962 Chevy Bel Air not shifting on time
1962 CHEVROLET BEL AIR
DSCAYOLA
Transmission problem
1962 Chevy Bel Air V8 Two Wheel Drive Automatic
350small block, 350 auto trans. I recetly removed distributor and had trouble getting back in correct place, but ok there now. Problem is now trans is not shifting correcty, it is staying in gear to long. Anything I could have moved or not put back correctly? The problem started the drive right after I got things back in order with the distributor. thanks for the time. Dan
Aug 23, 2009 at 3:28 PM
DOCFIXIT
  • 18,828 POSTS
Vacuum line to governor on trans runs right up by dist. look for vacuum lie going to metal tube behind and to left of dist. if attached check to see if it got pulled of GOV on rear of trans. pass side.
Aug 24, 2009 at 3:16 AM
