1961 Chevy Bel Air rear axle seal replacement
TEENAMAILLADY
Drive Train Axles Bearings problem
1961 Chevy Bel Air V8 Automatic
We have a 1955 Chevy bel air and we need to know how to replace and where the rear axle seal is. Is there anyway you could send me a pic to look at do so much better looking at a pic. Thanks
Jul 30, 2010 at 6:38 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Unfortunately this car is way to old for our data base, i will see what i can come up with, but i would be thinking that the seal is on the axle and the bearing will have to be pressed off to change it, there will be a small heat shrink retainer ring as well, all these are not reusable and they should come in a axle bearing kit, check this out.
mark (mhpautos)
Jul 30, 2010 at 5:07 PM
TEENAMAILLADY
Thanks appreciate the info if you come up with anything else please let me know. Again thanks have a good day. Teena
Jul 30, 2010 at 10:04 PM
