1961 Chevy Bel Air 1956 rebuilt transmission
1961 CHEVROLET BEL AIR
2,500 MILES • V8 • 2WD • AUTOMATIC
MIKE LEVY
Since the year does go back as far as 1956, I used the oldest year you had to offer..sorry.
A mechanic shop placed a 350GM Crate motor and a GM rebuilt transmision. The transmission is a 700 O/D.
The transmission leaks oil when the car sits for 2 weeks or more.
The mechanic said he has tighten up and replaced all the seals and said all transmissions leak.
I am not a mechanic but find the leak problem advice from my mechanic not right.
Thanks for any help,
MikeL
Feb 15, 2010 at 3:56 AM
HMAC300
  • 48,601 POSTS
no transmissions don't leak. If it is newly rebuilt then it should not leak. Thereis either a bad o ring gasket or seal that is leaking. Or a loose line. If your mechanic can't or won't fix it then take ti to a trans shop they will. Or they will tell you where it is leaking from.......
Feb 17, 2010 at 9:40 AM
