1960 Chevy Bel Air car stored for 40 years
1960 CHEVROLET BEL AIR
26,000 MILES • V8 • 2WD • AUTOMATIC
DB112525
I am intersested in a car that was stored for 40 years. What problems could this pose and what should I look for ? Thank you for your help
Mar 2, 2009 at 5:06 AM
RICH CRITES
  • 75 POSTS
All of the seals in the car will probably need to be replaced. Engine, transmission, rear axels, hydraulic system (master cylinder, wheel cylinder, ) Rubber brake lines. You will have to flush the radiator. probably have to change the water pump. Drain and flush the gas tank (it may have rust in it) Change the spark plugs and wires. I think it would make a great project car. Good Luck.
Apr 7, 2009 at 10:21 AM
