1960 Chevy Bel Air
BRUNO181
Steering problem
1960 Chevy Bel Air V8 Two Wheel Drive Automatic
tHIS IS REALLY A QUESTION ABOUT A 1956 BEL AIR WANTING TO PULL THE STERRING COLUMN AND NEED TO KNOW HOW TO DO IT
Sep 17, 2008 at 1:17 PM
JERRYGOODWRENCH
  • 77 POSTS
first is to mark everything exactly the way it is now.(str coupler at str box,shift linkage,all wiring,clips,bolts ,ect ect. spray with pb blaster or wd 40,then draw youself a diagram of how everything goes,then get abook on the 56 chev.Some of the illustrations are not exactly right so double check everything. You may have to replace frayed wires,broken bolts so be prepared. When you finally get it out lay everything out exactly the way it came out.Dont get frustrated and be patient..
Apr 17, 2009 at 11:19 PM
