1959 Chevy Bel Air removing the front driver window in a 19
SHERYLANN
1959 Chevy Bel Air
How do you remove and replace the front driver side window in a 1955 chevy belair sedan? I have located the glass but need to remove the old window.
Jul 22, 2008 at 7:22 AM
BOWTIE BABY
  • 101 POSTS
It should have 2 bolts that connect it to the window regulator. Remove door panel to gain access to the bolts, then simply wiggle the window out. You may have to remove some of the moulding in the window slot.
Feb 5, 2009 at 7:13 PM
