Hello:
They had the car on the lift and showed me that one of the front wheel and suspension could be moved up and down a bit. They said that this indicates a problem with the front strut mounts (too much play in them). They said it was for both front wheels. I was surprised I would have a problems because the car has low mileage
How much up & down movement of the wheel when it is on a lift is typical. Is what I described a concern or could this just be inventing a problem?
Thanks. -David
Thanks. -David
Aug 30, 2010 at 3:30 PM
