2008 Chevy Aveo
2008 CHEVROLET AVEO
MATTHEW73
Brakes problem
2008 Chevy Aveo 4 cyl Front Wheel Drive Automatic
How do I get the Brake light switch off?
Oct 14, 2010 at 8:00 AM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
Caution: Refer to Battery Disconnect Caution .
1. Disconnect the negative battery cable.
2. Disconnect the stoplamp switch electrical connector.
3. Twist the switch, and remove the switch from the brake pedal bracket.
Installation Procedure
1. Adjust the stoplamp switch. Refer to Stop Lamp Switch Adjustment (See: Adjustments).
2. Connect the negative battery cable.
2. Remove the stop lamp switch. Refer to Stop Lamp Switch Replacement (See: Service and Repair).
3. Pull out the shaft of the stop lamp switch to its maximum setting point.
4. Connect the stop lamp switch electrical connector.
5. Depress the brake pedal to the bottom.
6. Install the stop lamp switch in the brake pedal bracket hole by twisting.
7. Release the brake pedal slowly until reaching the end of the stop lamp switch shaft, the stop lamp switch will be adjusted of itself by the reaction force of the brake pedal.
8. Connect the negative battery cable.
Oct 14, 2010 at 8:21 AM
