I have same problem of water evaporation. I have not seen any leak and look it is a manufacturing problem, please reply.
Thanks
Aug 26, 2008 at 7:12 AM
SNAPONADDICT
MEMBER
depending on what engine you have you mav have a leak around the two coolant plugs to a coolant passage under the valve cover i have run in to it a few times the fix is to remove the plugs apply thread sealant and reinstall i beleive the torque is 76 ft-lbs hope this helps
Feb 4, 2009 at 2:46 PM
