The car turns over and I have 12v on the battery. I think that it will not start because the fuel punp may be bad. I checked the fuse for the fuel punp and dc volts are going thru it and it was good. The relay for the fuel pump, tested good. I ran a condenuity check through the fuel pump and it check ok. It read about 230-280 kilo owms of resistance. However the fuel pump may be jammed some other way. Or maybe its something else all together. Is there like a module on these cars, kind of like the 90's Fords? What do I need to do to repair this problem?
May 5, 2010 at 4:50 AM
