Stalls at Idle
2006 CHEVROLET AVEO
50,000 MILES • 4 CYL • 2WD • MANUAL
JOBURNET
The problem is that the engine frequently stalls at idle. I can keep this from happening by giving it some gas to keep the engine speed up. A check engine light comes on sometimes but goes away so I have not been able to read the code.
What puzzles me is that sometimes it stalls out almost every time it is in idle, and other times it has no problems at all. Could it be a lose connection somewhere or a bad value at startup?
Mar 1, 2010 at 7:48 AM
  • 55,423 POSTS
This is common when you have a vacuum leak or the throttle body needs service. these guides will help us fix it:
and
https://www.2carpros.com/articles/stall-at-idle
Dec 13, 2020 at 5:15 AM
