2006 Chevy Aveo Headlights
108,000 MILES • 4 CYL • FWD • AUTOMATIC
RUPERTNEGLEY
usually when I start the car my runner lights come on recently I turned on the car and the runner lights did not come on and the low beam head lights do not come on but if I switch to high beams I have lights what is wrong and what do i need to check
Apr 23, 2010 at 3:59 AM
BAD_ELMO
2007 Chevy Aveo5. 80,000 mi.
I have the same problem. Last night I started her up, turned on the head lights, there was a quick flash and then nothing. The high beams still work but no low beams. The trouble shooting I've done so far: checked relay OK. Checked fuses OK.
Next I'll check for voltage at the lamp connections if I'm getting current there I'll check for continuity across the lamp's low beam filament. Please correct me if I am forgetting anything
Thanks in advance. Any and all insight will be greatly apreciated
Mar 17, 2012 at 8:21 PM
