2006 Chevy Aveo engine coolant
20,000 MILES • 4 CYL • 2WD • MANUAL
CIRE_NM
in saudi arabia, most shop have this long lifecoolant available, question, is it advesable to use this coolant on the chevy aveo vehicle? owners manual is a bit unclear on wheather this type of collant can be use.
Apr 17, 2008 at 11:29 PM
RHALL77
  • 3,361 POSTS
my suggestion is to use the factory recommended coolant. even the dex cool they suggest that you dont have to replace for 100,000 mile still clogs stuff up. no matter what i would still flush the cooling system when needed and install new coolant. this will save you in the long run.
Jun 15, 2017 at 5:25 AM
