2006 Chevy Aveo air noise
29,000 MILES • 4 CYL • FWD • MANUAL
CIRE73NM
Can you please give a sugestion on how i remove air sound inside the car when i'm driving above 120k. All windows are shot close, doors closed and lock but still i can hear sound of air humming while i'm cruising.
TY
Oct 14, 2008 at 7:46 AM
SOTERIN9796
I FINALLY found it!!!!!! Just roll your passenger window up and down several times, each time go "up" a little tighter. Also, get an air compressor nozzle and force air pressure around the passenger door window seal.
I've been looking forever...I am thrilled that this was the solution.
Just to summarize my original issue...when I drove in high winds at high speeds (over 65), I would hear a howling noise that sounded like a bad trumpet player that only knew one note.
Jan 3, 2009 at 11:50 AM
JACKR
  • 5 POSTS
I also have loud air hum at high speeds. Mine comes from the heat/AC vents as air enters the vent in front of windshield. Design flaw in these little Daewoes. Decided I got what I paided for and live with it.
Jun 25, 2009 at 1:02 PM
