Hello -
If you need to get back with us, please let us know if this is just an Aveo, or an LS or LT.
Well, white smoke is normally an indication of a blown head gasket or one that is leaking, head slightly warped. That is the engine coolant burning in the combustion chamber.
Has your coolant level gone down? Has your oil level gone up and does it look milky colored?
Since you had the check engine light, what you might do, is go to Auto Zone (AZ) or O'Reilly's (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don't get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter.
Again, if you need to get back with us, please provide the info above and the results from AZ. This will help us with your diagnosis.
SPONSORED LINKS
Monday, November 24th, 2008 AT 9:54 PM
