2005 Chevy Aveo RADIO does not working and door open clos
2005 CHEVROLET AVEO
68,000 MILES • 4 CYL • FWD • AUTOMATIC
AZIZGUMUSAY
hi
RADIO does not working and door open close clock resets
also I CAN NOT pull out the fuse because fuse inside the kind a shell how I am GONNA PULLout it
the other fuses with the puller very easy
(ps after the one day I was rushing the battery jump action I connect the polarities wrong and then happened since I SHOULD more carefully)
Feb 13, 2010 at 8:24 PM
MJKXXL
[quote:2cc62feaeb="AZIZGUMUSAY"]Electrical problem
2005 Chevy Aveo 4 cyl Front Wheel Drive Automatic 68000 miles
hi
(ps after the one day I was rushing the battery jump action I connect the polarities wrong and then happened since I SHOULD more carefully)[/quote:2cc62feaeb]
I am having the EXACT same issue. Same car, mine is a 2005 Aveo 5 Door with 86,000+ on it. I was going to go through the car this summer and try to figure out where the short is, but have not done so yet. If you are having the EXACT same issue, I wonder if it is a problem in the fuse block. I can garuntee you that it has nothing to do with jumping the car since I never have jumped mine, or had cables on it and this problem still happened. If anyone on this board has any ideas, that would be fantastic. I will continue to check here, and if I find the solution, I will post it for sure.
Mar 4, 2010 at 3:27 PM
