2005 Chevy Aveo lights
68,000 MILES • 4 CYL • FWD • AUTOMATIC
SURENUFF
My dashboard lights, rear light on right side and front yellow light is out, fuses and bulbs are good .what could be problem,
Jun 29, 2010 at 4:59 PM
SURENUFF
[quote:2a9b68fc1d="surenuff"]Electrical problem
2005 Chevy Aveo 4 cyl Front Wheel Drive Automatic 68,000 miles
My dashboard lights, rear light on right side and front yellow light is out, fuses and bulbs are good .what could be problem,[/quote:2a9b68fc1d]
Later; July 6.2010,tuesday
I just got back from the dealer . They put my 2005 oveo car on machine .Found a shortage coming from a wire that was burned at the bottom of the 101 splice pack[box].Replaced the wire and found where it wasnt grounded, Hope this helps someone with same problem.. dash, rear light and front runner light all work now,, costed $166.80. Long way from replacing the pack. the pack would have run in the $1.ooo's .
Jul 6, 2010 at 11:32 AM
SURENUFF
[quote:6a8413753f="surenuff"]Electrical problem
I just got back from the dealer . They put my 2005 oveo car on machine .Found a shortage coming from a wire that was burned at the bottom of the 101 splice pack[box].Replaced the wire and found where it wasnt grounded, Hope this helps someone with same problem.. dash, rear light and front runner light all work now,, costed $166.80. Long way from replacing the pack. the pack would have run in the $1.ooo's . problem,[/quote:6a8413753f]
Jul 6, 2010 at 11:34 AM
