Lock Cylinder fell into door, How do you remove the window crank. So the door panel can be removed to retreive / repair lock cylinder?????????
Apr 14, 2008 at 11:45 AM
KW5000
MEMBER
1 POST
With crank handle in 6:00 position, insert a flat piece of metal about the thickness of a quarter. Push down, this expands a spring steel e-clip and allows you to pull the handle off. If you are then going to pull the door off, go ahead and order that black plastic triangle piece where your mirror adjustment comes through the door. I have broken it every time I removed the door.
