2005 Chevy Aveo Brake Lights
2005 CHEVROLET AVEO
35,000 MILES • 4 CYL • 2WD • MANUAL
DHENDRICKS
The brake lights will not come on. I have replaced the fuse and all other lights,turn signals, back up lights all work. Both rear brake lights and the light in the back window do not work. Is there a secondary fuse somewhere that may need to be replaced?
Jul 2, 2008 at 1:58 AM
RHALL77
  • 3,361 POSTS
i think there use to be a recall for that. call your local dealer and see. i dont remember but i think they replace the fuse box for the concern. im not for sure
Jul 2, 2008 at 2:04 AM
CAITLINOLIVEIRA
I had the same problem a couple months ago - my brake lights were not coming on even though the bulbs were good and the fuse was fine.The problem was the brake light switch. Once the switch was replaced the brake lights worked fine. Hope this helps.
Jul 12, 2008 at 3:15 PM
ANGELAGONZALES
The brake lights will not come on. I have replaced the fuse and all other lights,turn signals, back up lights all work. Both rear brake lights and the light in the back window do not work. Is there a secondary fuse somewhere that may need to be replaced?[/quote]
Some one please tell what i should do?
Mar 23, 2009 at 7:32 AM
ASIAN_SENSATION2K7
I have a similar problem with the same car only it's my passenger tail light and dash light that won't come on. But mine is the same... it's not the fuses or the bulbs. The only other thing I can think of is a problem with the wiring or something but I can't figure it out either.
Jun 27, 2009 at 5:40 PM
