2005 Chevy Aveo
SOFRESHANDSOCLEAN
2005 Chevy Aveo Engine Size unknown Wheel Drive Type unknown 39 miles
Who do you look to when the cylinder lock has falling inside the drivers door, and how much should I spend
Dec 23, 2007 at 5:21 AM
JSCZYNSKI
  • 48 POSTS
[quote:679a4d5ceb="SoFreshAndSoClean"]2005 Chevy Aveo Engine Size unknown Wheel Drive Type unknown 39 miles
Who do you look to when the cylinder lock has falling inside the drivers door, and how much should I spend[/quote:679a4d5ceb]
Take it to the chevrolet dealer. if the vehicle only has 39 miles on it it will be covered under warranty unless they suspect someone tried to get into your vehicle than you may have to go through your car insurance and body shop. i'd start at the service department first. it should be ready in about an hour. good luck. as to cost it will probably cost you nothing.
Jan 24, 2008 at 11:45 PM
