change the ABS wheel sensor?
57,600 MILES • 4 CYL • FWD • AUTOMATIC
EMOREJXX
what happens if i change the ABS wheel sensor myself?
Jul 13, 2009 at 8:32 AM
If you replace it using the guides below then you should be able to replace it properly.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
I attached the info below on how to replace the sensors. Please let us know if you have other questions. Thanks
Mar 9, 2021 at 11:22 AM
