2004 Chevy Aveo oil in spark plug well
61,250 MILES • 4 CYL • 2WD • AUTOMATIC
F_FLICK
Changed plugs and found oil in #3 well. What is the cause of this, and how should I fix the situation?
Mar 20, 2008 at 8:26 AM
BLACKOP555
  • 10,386 POSTS
either your piston rings are worn and will need to be replaced or your valve seals are deteriorated and letting oil leak in.
Mar 21, 2008 at 6:20 AM
LUCKINS
I know that some of these cars have had problems with the valve guide seals. Is there a misfire or an engine light code? I don't know if this is a warrantied repair unless you have an extended warranty. Otherwise, it's an expensive fix. It wouldn't hurt checking it out.
Mar 27, 2008 at 2:52 PM
