2004 Chevy Aveo oil in spark plug well
F_FLICK
  • 2004 CHEVROLET AVEO
  • 4 CYL
  • 61,250 MILES
Changed plugs and found oil in #3 well. What is the cause of this, and how should I fix the situation?
Thursday, March 20th, 2008 AT 3:26 PM
BLACKOP555
  • 10,371 POSTS
Either your piston rings are worn and will need to be replaced or your valve seals are deteriorated and letting oil leak in.
Friday, March 21st, 2008 AT 1:20 PM
LUCKINS
I know that some of these cars have had problems with the valve guide seals. Is there a misfire or an engine light code? I don't know if this is a warrantied repair unless you have an extended warranty. Otherwise, it's an expensive fix. It wouldn't hurt checking it out.
Thursday, March 27th, 2008 AT 9:52 PM
