2004 Chevy Aveo Compression
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
COLORADOLADY
I've lost compression when driving. The RPM has to go higher in order for the transmission to shift gears. I've checked the oil, tranmission fluid and coolant and all seem fine. Any other suggestions? I can't afford a mechanic right now and have some mechanical knowledge and experience.
Apr 28, 2008 at 4:27 AM
RHALL77
  • 3,361 POSTS
how do you know you lost compression. did you perform a compression test. what are the results may i ask. give me a little info and i can help you.
Apr 28, 2008 at 4:47 AM
