Vibration from 3rd to 4th gear
CHEVROLET AVALANCHE
GOBOYSGO
Bought a 05 with 23500 2 weeks ago. Just noticed a viration when I get to about 50-55 or when it shifts in 4th. But when im getting onto the freeway and giving her a little gas I dont notice it at all. Just seeing if anyone else is going through this also
Oct 9, 2007 at 3:56 PM
CHEVY22
  • 1,375 POSTS
start simple and have the u joints checked and the tires balanced and rotated
jim
Oct 9, 2007 at 11:07 PM
6971WARREN
Had same problem on 2007 with 20,000 miles. transmittion cluthes coming apart. did a rebuild at about 1200.00 dollars and worked. repair tech said that water had gotten into the trans and that there is a service alert thatsays the water drain from the front window will under certain conditions actually run into the transmittion. seemed to be my problem
Jul 10, 2009 at 5:58 AM
