2007 Chevy Avalanche Locked Passenger Door
79,000 MILES • V8 • 4WD • AUTOMATIC
CURTIS LANE
How can I get my passenger door to unlock?
It started when my wife close the door and it didn't catch as it was closed. I told her to hold it (door) and I pressed the locks from the driver side. Once I unlocked the doors again the door would not open. The lock still engages but the door handles will not unlatch the door. I've tried the inside and outside handle of the passenger door with no avail.
Mar 16, 2010 at 2:07 AM
RHALL77
  • 3,361 POSTS
is the door shut now, or is it open and not catching when you close it?
Mar 18, 2010 at 2:13 AM
CURTIS LANE
The door is shut now.
Mar 18, 2010 at 2:37 AM
RHALL77
  • 3,361 POSTS
but it is not opening, correct?
Mar 18, 2010 at 5:42 AM
CURTIS LANE
That is correct. The door will not open at all no matter how I try to open it.
Mar 18, 2010 at 6:51 AM
RHALL77
  • 3,361 POSTS
its tricky but you can remove the door panel without damaging it. remove the boltsthat secure it by the release handle and arm rest. lift up to release it from the door. DO NOT pull out wards to release it. then you should be able to get at the latch to see if something came disconnected if not release the latch and replace it
Mar 18, 2010 at 7:42 AM
RHALL77
  • 3,361 POSTS
i think there is one behind the door lock slide also.
Mar 18, 2010 at 7:43 AM
CURTIS LANE
Thank you. I will take a look at it and see.
Mar 18, 2010 at 8:00 AM
