ABS light on?
KAMRYN STOREY
  • 2007 CHEVROLET AVALANCHE
I would like to know if it is safe to drive with the ABS light on? Do I need to go in for repair soon or does it matter?
Wednesday, September 9th, 2009 AT 3:32 PM
RHALL77
  • 3,361 POSTS
What happens on these is the front hubs go out causing the ABS wheel speed sensor to stop working but the be sure here is a guide to help you run the codes.
https://youtu.be/rTtAnsOlZU4
this guide will walk you through the hub replacement
https://youtu.be/ZgiPRG6jffc
Wednesday, February 13th, 2019 AT 7:26 PM (Merged)
SFLANAGAN
  • 2003 CHEVROLET AVALANCHE
  • V8
  • 4WD
  • 160,000 MILES
2003 Chevy Avalanche ABS light on? Just started today. Am I looking at a high cost fix?
FIXITMR
  • 9,990 POSTS
Get code read, could just be a wheel sensor issue.
SHELDON123
  • 2004 CHEVROLET AVALANCHE
  • 5.3L
  • V8
  • 4WD
  • 223,000 MILES
My abs light came on and wont shift out of 1st gear, replaced the out put sensors, is there an input sensor on the transfer case how many sensors r on the transfer case just wanting to know if there is a input sensor at the front of the transfer case or at the end of the tranny
CARADIODOC
  • 34,366 POSTS
What you're describing involves two totally different systems. Speed sensors on a part of the drive train are for shifting and the speedometer. The anti-lock brake system uses a wheel speed sensor at each front wheel, and to save money, GM usually uses just one sensor in the rear to measure both rear wheel speeds together. Unless something has changed, that one sits on top of the differential housing. They did have some older models that used the speed sensor at the rear of the transmission for the anti-lock brake system.
The place to start is not by replacing random parts. Start by reading the diagnostic fault codes, but understand those never say to replace parts. They only indicate the circuit or system that needs further diagnosis, or they describe the unacceptable operating condition. A part referenced in a fault code is only the cause of that code about half of the time. You also have to look at the wiring and connectors.
Most likely you'll have to visit a mechanic to have ABS codes read. Many auto parts stores will read codes for you for free, but they can only read engine codes.
