2007 Chevy Avalanche
10,633 MILES • V8 • 4WD • AUTOMATIC
FIDELL
My avalanche had a lift put on it prior to me buying it. I had the tires and wheels changed once I purchased it. My questions is: If I needed an alignment after I changed the wheels from a positive offset to a negative offset? My tires are worn out after only six months because the alignment was bad.
Aug 25, 2008 at 10:10 AM
DENNYP
  • 1,824 POSTS
Yes, it changes the angles of the tires when the wheel offset is changed.
Aug 26, 2008 at 1:24 AM
