2006 Chevy Avalanche cleaning fuel injector
20,000 MILES • 6 CYL • 4WD • AUTOMATIC
CAHHAR708
I took my car to jiffy lube for a service, they cleaned my fuel injector for 59.99. Next day a light comes on in my car, it is themalfunction lamp. I took my car to a dealer who said jiffy lube damaged my fuel injector and it would be 480.00 to repair. Jiffy lube said that is impossible as they only flush ir out with cleaners. In the meantime the light is still on in my vehicle and it wont pass an emissions with this light on. What should i do?
Feb 29, 2008 at 3:28 AM
THE FACTORY MAN
  • 50 POSTS
Read this information about Jiffy Lube and decide for yourself.
http://www.consumeraffairs.com/automotive/jiffy_lube.htm
Mar 3, 2008 at 1:58 AM
DENNYP
  • 1,824 POSTS
Some of the injector cleaners on the market can damage the GM injectors. I recommend cleaning the injectors with GM top engine cleaner diluted with gasoline. You can also use Chevron Techron fuel system treatment. Watch out for jiffy lube.
Mar 17, 2008 at 3:49 PM
THE FACTORY MAN
  • 50 POSTS
Just use Top Tier Gas and you shouldn't have to worry about dirty injectors or carbon build up.
Mar 18, 2008 at 2:33 AM
