where is the evap fuel valve located.
76,000 MILES • V8 • 4WD • AUTOMATIC
SCOTTYDO11
I already replaced the gas cap due to getting a message n the dash (tighten fuel cap) I am still getting the message and now my check engine light is on. I had the code read and it is coming up large leak. I am not leaking fuel. So i would think t is my evap valve. Where is it located?
Sep 17, 2008 at 1:37 AM
CRAIGSROBOTICS
for codes reading 0455, the fuel evap valve is located under the rear of the truck close to the passenger side wheel....follow the fuel hose to the large box under the vehicle, and look to the right of it. It is about the size of a soup can with a couple of hoses and a wire harness leading to it. I just came from the dealer. Cost of the valve is $48, and labor was $140. Took less than an hour. Description was "large evap leak detected. Evap valve stuck open. Found by using smoke tester"
Oct 15, 2008 at 6:56 AM
GIBLET
where is the location of my evap canister? for years i have seen them under the hood, but not on this model. i need to change out the purge solenoid that bolts to the canister.
Jul 15, 2019 at 9:20 AM (Merged)
RHALL77
  • 3,361 POSTS
the purge solenoid it mounted under the hood, here is the location in the diagrams below. Check out the diagrams (Below). Please let us know what happens.
