Location of jack and handle to change a tire
2005 CHEVROLET AVALANCHE
BNAYLOR
Trying to change a, where is the jack and handle, and how do you get the spare tire down?
Nov 22, 2009 at 9:16 AM
  • 110,244 POSTS
The jack assembly should be under the rear seat. As far as the tire, look along the top of the bumper near the plate. You will see where to insert the jack to lower the tire.
Dec 6, 2009 at 11:53 AM
JDM333
I know this is old, but if anyone is still looking for answer. The jack is under seat and remove panel on passenger side, get jack. Pokes you need to lower spare are in one of the tool boxes. Put poles together right way and open the door with key on back bumper. Stick poles in and turn counter to lower wheel. If wheel has never been down or a long time and is rusted up there, use jack and pole or whatever and give wire some slack and push just center portion of the mechanism all the way up till it unlocks. It has secondary locking mechanism.
Sep 26, 2020 at 5:12 AM
