2005 Chevy Avalanche
115,000 MILES • V8 • 4WD • AUTOMATIC
JOE NAILS
my avalanche is loosing power completly it will not go past 2000 rpm , and does not shift no codes come out on dtcs i took it to a transmission shop ,the tech doesnt think its transmission related, i have a hypertech chip intalled in it but before i took it in i set it back to stock settings, the problem comes and goes and then the truck runs perfect was wondering if its a silenoid, sensor, or computer related some times it does it right away or it could take several miles.
Jan 13, 2010 at 5:07 PM
SCOTTY DEE
  • 592 POSTS
If there are no codes when this happens it could be a fuel delivery problem that is intermittent. I would suggest a fuel pressure reading the next time 2000 rpms is the best it will do. Check fuel filter if equipped with one.
Jan 26, 2010 at 4:08 AM
