2005 Chevy Avalanche
73,256 MILES • V8 • 4WD • AUTOMATIC
JBICKEMS
my truck over heats but stops when the heat is on
Dec 30, 2009 at 7:00 AM
HMAC300
  • 48,601 POSTS
try rplacin the thermostat first. another thing when the truck overheats, shut it off and feel the radiator . It should feel about teh same temp with your hand all over. If you feel cold spots, replace the radiator as it shouldn't have those....... Also if you have a "bug screen" in front of your grille remove it as it stops 15% of the air flow for cooling.
Dec 31, 2009 at 1:20 AM
