2004 Chevy Avalanche switching into 4 high
2004 CHEVROLET AVALANCHE
52,112 MILES • V8 • 4WD • AUTOMATIC
GOTTWIN
Upon switching into 4 high the light blinks and a message appears stating 4 wheel drive needs servicing.
i go into 4 wheel drive 6 times a year.
I put a code reader on the port and no errors were shown.i then tried to switch into 4 h with code reader pluged in.still no code.
im able to select 4 low and it goes in and light stays steady.but the 4 high still blinks.
note the lights are on the selector switch.a solid green mean its engaged into 4 wheel drive.
thanks for the time
Jan 16, 2010 at 2:16 AM
SCOTTY DEE
  • 592 POSTS
A generic code reader will not read body or tranfer case codes. You will need a scan tool that can read all modules. More than likely there is a problem with the transfer case position sensor and/or encoder.
Jan 26, 2010 at 4:03 AM
