2004 Chevy Avalanche Oil Pressure Gauge Reading High
JAZZ90
Engine Performance problem
2004 Chevy Avalanche V8 Two Wheel Drive Automatic
The oil pressure gauge started running up to 80 this past weekend. I didn't do anything differently to have caused this. It normally stays at or slightly above 40. I noticed the oil was a little low, so I added some (not much). It's still running close to 80 while on the highway. What could have caused the change and is it dangerous to drive?
Sep 7, 2010 at 6:25 AM
  • 75,988 POSTS
Is there any type of engine knocking noises if not. Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch still abnormal could mean the oil pump pressure relief valve is not opening
Sep 7, 2010 at 9:51 AM
