2004 Chevy Avalanche Noise after change the oil
90,000 MILES • V8 • 2WD • AUTOMATIC
AVALANCHE2004
Hi
I have a Avalanche 2004, most recently change the oil an filter for service (each 3,000m) but some days after that, start to do a stranger noise like this (ta,tac,tac,tac,) this happen in the mornings when start and after parking for many hours.
The noise stop after 1 or 2 minutes, the truck dont have any other problems. runs very well.
(the arrow of oil meter go to up when you speed up an keep in the middle, but if you dont speed up, the arrow down 1/4 in the meter)
Sorry for my english but my first idiom is spanish.
Please help me because i dont know if need fix this before change the oil again.
Jun 29, 2009 at 11:17 AM
MERLIN2021
  • 17,250 POSTS
you are describing hydraulic valve lifter noise, high mileage cars can suffer this fate, if you want you can replace worn lifters and pushrods, may not be woth it though. I suggest driving it until a skip in the engine develops...if you can live with it, your oil pressure seems to behave normally! Only thing to watch is if the oil is full! And the right viscosity is bieng used, wether its 10-31 or 10-40, it should tell you on the stick.
Jun 29, 2009 at 11:48 AM
AVALANCHE2004
Tnks a lot for you answer,
Now do you can say to me where is locate the valve?
Can obtain a manual for change this?
Is to much expensive?
Can find this in any store of autm parts?
Tnks again
Happy July 4th!!!
Jun 30, 2009 at 10:10 AM
MERLIN2021
  • 17,250 POSTS
I do provide answers to automotive question, they do not pay me enough to give classes on engine dissasembly! This is NOT something you could do if you are asking this question! Check oil level and pressure, ok, other than that, MUCH more knowledge isr equired today! Do you think you are qualified to tear an engine apart and put it back together? Or would someone be helping you?
Jun 30, 2009 at 10:33 AM
