2004 Chevy Avalanche erratic gauges
NEVR4GET3CAR
Computer problem
2004 Chevy Avalanche V8 Four Wheel Drive 80000 miles
Hi The first thing i noticed was that the check 4 wheel drive light came on during start up (and still does). The axles and bearings check out ok. Then a few months later the gauges would be erratic. Sometimes the oil pressure gauge will go to zero and other times it will go off the max reading. Often times the speedo will gradually start going toward the zero example at highway speeds it may show 35 mph. Is there a computer that governs all of these and if so where is it located or is it perhaps other problems? I feel that the oil pressure is ok or the engine would have suffered catostrofic failure by now. The temp seems to be ok and gauges still continues to give me fairly accurate instantanious mpg so i feel that at least part of the gauges are working properly. Is this a problem that i can handle or should i take it to a mechanic. I am comfortable working on old pre-computer type autos.
Jan 24, 2010 at 12:00 PM
SCOTTY DEE
  • 592 POSTS
Does the 4WD engage and work properly? That could be a seperate problem. It does sound as if the cluster is a problem. Remove the cluster and check the connection at the back of the cluster. If connections are good, the cluster is bad. A very common problem with GM clusters.
Jan 26, 2010 at 3:49 AM
