2004 Chevy Avalanche check engin light
BILLYOUNG
Computer problem
2004 Chevy Avalanche V8 Two Wheel Drive Automatic
how do I reset it so it is not on. where is the canaster purge soleniod located
May 24, 2008 at 5:24 AM
RHALL77
  • 3,361 POSTS
yo will need a code scanner. you can stop at most local parts stores to have the check engine light cleared. the purge solenoid is located under the hood. what code are you getting, sounds like it also could be a gas cap or a vent valve
Jul 28, 2008 at 1:39 PM
