2003 Chevy Avalanche PO300 MISSFIRE CODE
ROBINSLACK
Engine Mechanical problem
2003 Chevy Avalanche V8 Two Wheel Drive Automatic
i am getting a po300 missfire code, and have no fire to cylinders 1,3,5,7, the cylinders are firing , but are missfires
May 9, 2010 at 1:44 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
May 9, 2010 at 3:25 PM
ROBINSLACK
we have done a compression check, changed mas sensor, map sensor, new pulgs, checked oxygen sensor, still missfiring and running lean, all the problems started when I was going down the interstate, and put the truck on cruise control, could my electronic trhottle body be the culprit.
May 15, 2010 at 4:30 AM
