2003 Chevy Avalanche
HASBEEN6489
  • 2003 CHEVROLET AVALANCHE
  • V8
  • 4WD
  • 45,000 MILES
The passenger front door of my 2003 avalanche has lost all power. No mirror, window, or door lock. Everything else works fine. Its probably a fuse but which one?
Wednesday, July 21st, 2010 AT 3:50 PM
  • 109,885 POSTS
Do the other windows, locks. Still work? If so, the fuses are okay. Between the door and door frame is a rubber boot covering the wires that go in the door to supply power. Check the wires under the boot to see if any are broken or damaged.
Let me know what you find.
Tuesday, November 2nd, 2010 AT 9:57 PM
HASBEEN6489
Thank you for a reply. Everything works but one door &remote door locks. I had computer reset but it only lasted a few days. The wires under the door boot appear to be ok
Thursday, November 4th, 2010 AT 6:50 PM
  • 109,885 POSTS
Which computer was reset? You mentioned it only worked for a few days. That tells me it is tied into the computer and not a problem in the door.
Thursday, November 4th, 2010 AT 10:14 PM
