Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Avalanche
Engine Cooling
Water Pump
Leak
2002 Chevy Avalanche WATER PUMP LEAKING ?
2002 CHEVROLET AVALANCHE
TATTOODEBERA
MEMBER
Engine Cooling problem
HOW DO I REMOVE WATER PUMP
Mar 6, 2009 at 6:25 AM
Experienced Mechanic
To remove the pump, drain the coolant, remove the fan from the engine front, remove the radiator hose and thermostat, remove the belt, and unbolt the water pump. Reverse the order to replace.
Mar 23, 2009 at 8:37 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
