2002 Chevy Avalanche WATER PUMP LEAKING ?
2002 CHEVROLET AVALANCHE
TATTOODEBERA
Engine Cooling problem
HOW DO I REMOVE WATER PUMP
Mar 6, 2009 at 6:25 AM
  • 110,240 POSTS
To remove the pump, drain the coolant, remove the fan from the engine front, remove the radiator hose and thermostat, remove the belt, and unbolt the water pump. Reverse the order to replace.
Mar 23, 2009 at 8:37 AM
