2002 Chevy Avalanche U joints
RAGU_TD21
Drive Train Axles Bearings problem
2002 Chevy Avalanche V8 Four Wheel Drive Automatic
Hello my front drive shaft u joint is shot....
Just wonder how to change it. They are different looking u joint, i havnt seen b4. It doesnt have c clips or ring locks...It has cups on each end but there is no blots holding it down.... Are they pressed in?
Apr 15, 2010 at 12:06 PM
MERLIN2021
  • 17,250 POSTS
They are held with epoxy, heat with a torch until the glue squibs out of the small holes on the side of the yoke. then press as usual, and use the c clips provided with then new joints.
Apr 15, 2010 at 12:17 PM
