2002 Chevy Avalanche STARTING / IGNITION
80,000 MILES • V8 • 4WD • AUTOMATIC
DWHARPER1963
I'VE RECENTLY REPLACED THE PLUGS AND THE ENGINE RUNS PERFECTLY. IT EVEN STARTS ON THE 1ST TRY WHEN THE ENGINE IS COLD, BUT AFTER IT'S BEEN RUNNING FOR AWHILE, AND SITS FOR A COUPLE HRS, IT WON'T START ON THE 1ST TURN OF THE KEY, AND SOMETIMES NOT EVEN ON A 2ND OR 3RD TRY. IT WILL EVENTUALLY START, BUT WHAT COULD BE THE PROBLEM WITH THE DIFFICULT STARTING?
Sep 15, 2009 at 10:09 AM
PEAR69
  • 1,482 POSTS
It could be many things. First, check the compression of all the cylinders. This will give you an indication of the condition if the cylinders..Next- check the fuel pressure, it should be at-least 58psi..
Sep 16, 2009 at 2:44 AM
