Poor gas mileage
RAGU_TD21
V8 Four Wheel Drive Automatic
There is no check engine light on. I've changed the fuel pressure regulator. I didn't seem to be leaking but changed it anyways and it still doesn't seem any better on gas. I put injector cleaner in it every oil change 5000km's. Can the return fuel line be plugged? I've talked to the previous owner of the truck and he told me the truck just stalled on the highway and wouldn't start up. He got it towed to the GM garage and they changed the fuel filter and pump. It worked after that.
Feb 20, 2010 at 8:29 AM
  • 110,248 POSTS
The MAF sensor can be off a little causing the bad mileage but not enough to trigger a check engine light.
Here is a guide to show you what you are in for when changing the sensor out.
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Cheers
Jul 18, 2010 at 4:51 PM
CHRIS42772
I had this exact same problem once I replaced the sensor the truck never run better, thanks! I love this site.
Apr 16, 2018 at 12:12 PM
